ksteintrager's avatar
ksteintrager
Which modem router is best to replace c3700?
I purchased my Netgear c3700 in 2014 and I need to replace it. The square footage it needs to cover is around 3000 sq. ft.  I am considering either the c7000 or the c7500.  Please advise me on the best cable modem router to replace my old one? TIA
  • plemans's avatar
    In my opinion, I wouldn't replace it with a modem router combo. I don't like them combined as then the ISP controls the firmware and they usually don't update it for security. it does cost a bit extra to seperate out the modem and router but its worth it in ability to update the router, ability to replace a single one of the devices as needed, and the additional controls it gives you.
    Additionally, if you're using quite a bit of bandwidth, 3000sqft is starting to push the limits of single router solutions.
    • ksteintrager's avatar
      ksteintrager
      What would you recommend? My Netgear c3700 is not working well. I believe it’s lived it’s life.
      • plemans's avatar
        So a couple questions.
        what speeds are you paying for and wanting? the C3700 is good roughly to 100mbps
        How much area are you trying to cover? That and budget is going to be a key points with any router.
        What issues are you having? The C3700 isn't the fastest wireless device or faster internet service device but depending on your usage, troubleshooting might not be a bad idea.  Especially if its a modem/line issue and not a router issue.
