UncSam
Feb 28, 2017Follower
Which setup would you recommend for Xfinity?
Hello, I am currently looking to purchase a new modem and router or combo for my home network as mine is becoming outdated. I currently have Xfinity's fasted internet package and I am looking to...
Feb 28, 2017Guru - Experienced User
UncSam wrote:
I am looking to possibly purchase a Nighthawk C7000 Modem/Router Combo or an Arris 6190 paired with a Nighthawk R7000.
One thing to consider is how committed you are to Infinity. The C7000 can only be used if you use provider that offers cable broadband. If you wanted to switch to fiber or VDSL you'd be stuck.
Separates also give you some more flexibility when you want to upgrade.
Note you don't have to get an Arris if you are concerned about it. You could go with a Netgear CM700. But I think there is only one chipset available for 32x8 modems.
