avansents's avatar
avansents
Follower
Dec 03, 2022
Wi-Fi No Longer Broadcasts
I think my CAX80 router was trying to automatically update the firmware, and now it is not able broadcast Wi-Fi.
Whenever I go into the router configuration page, it has everything set to “Unknown”. I have factory restored it several times, and downgraded to the prior firmware version with no success.
My ISP is going to come out in a few days, but I don’t think it’s an ISP issue.
Any guidance, opinions, or positive energy that you can provide is much appreciated.
  • michaelkenward's avatar
    michaelkenward
    Two immediate things to check:
    • Is the power LED as it should be? If it isn't white you may have broken firmware.
    • Is the WiFi LED/button pressed?
    Note that there are two sets of firmware on these cable modem/routers. The modem bit is beyond your (and Netgear's) control. You can update the router bit.
    Does the router bit allow automatic unattended updates? Or did you tell it to go and get an update?
    How are you getting there?
    While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Cable Modems & Routers
    You might like to search there for messages related to your problem.
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    Check for various troubleshooting tips.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
  • FURRYe38's avatar
    What FW is currently loaded on the CAX? There is a new version available.
    After you factory reset the CAX and before you walk thru the setup wizard, have you unplugged the ISP coax from the modem then pulled the power adapter from the all socket for 1 full minuted then back in? Reconnect the ISP coax cable, then walk thru the setup wizard with a wired PC and web browser?
