jhex7000's avatar
Oct 14, 2016
WIFI analytics App
Is there a Netgear analytics app for Windows or IOS that I can use to view channel use with my dual band cable modem?
  • I knew I did this before but forgot - Netgear Genie for PC works fine and does the channel analytics if you dont have a supported router.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello jhex7000
    Sorry no app for IOS or windows you may be able to find a similar free app.
    DarrenM
    • jhex7000's avatar
      jhex7000
      Guide
