dspsfmprprl's avatar
dspsfmprprl
Follower
Aug 27, 2017
Wired Ethernet ports are significantly slower than wireless
I have a C6300 router/modem and pay for 200mbps internet service
When using wireless such as with my phone and laptop I routinely acheive download speeds of 220mbps. When using a wired connection speeds are typically around 50mbps, and never more than 65.
I have verified the situation with 3 different computers and multiple cables, including plugged directly into the router (i.e. no chance it's the wiring in my house). I have performed a factory reset and it hasn't helped.
My C6300 has no QoS support in the Genie, so I don't think it's related to any of that.
Does anyone have any suggestions of what to try?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Try testing something disable the wireless connections on the modem and see if the speed changes on the PCs I am wondering if something on the wireless is eating up the bandwidth.
    DarrenM
  • I just purchased a c3600 modem/router combo to replace the rental arris that comes with Comcast XFINITY.
    The wireless speeds are as expected. But just as you mentioned, the wired ethernet connections are 50-55 mbps consistently.
    I've tried different cables and different PCs/laptops, all with the same speed result of 50-55 mbps.
    At a loss as to what is going on.
    Any help?
