DudeRides's avatar
DudeRides
Xfinity Says I Need To Replace My CM3000
Hello,
A couple of days ago I had a technical support call with Xfinity regarding a streaming issue. During the call, they checked modem status and claimed that the modem was generating errors. They scheduled a tech visit to assess. Since I run my own CM3000 modem, the only thing the tech checked was line quality. The quality was determined to be good, all the way into the final connection to the modem. The tech suggested that the modem was bad.
I looked at the system log for the modem last night, and indeed there are a lot of critical messages, including SYNC errors and T4 time out errors.
Does the community agree that the CM3000 is suspect, or should I do more assessment of the line in?
Note: About a year ago the house next door was struck by lightning. It immediately cooked my TPLink router. The CM3000 seemed to not be affected, but maybe it was but it was able to work just well enough to get by?
Thank you.
  • The ISP is Xfinity.
    Xfinity has sent a tech to the building who claims that nothing is at issue with the line in.
    Xfinity has claimed that the issue is the modem (CM2000).
    That is why I sourced a new Xfinity gateway as well as a new CM3000.
    The current agenda is to ask Xfinity to test for modem issues from their servicing node to the current CM2000 - then implement the Xfinity gateway and test again. That will supposedly determine if modem issues/errors are/were with the CM2000 or an issue with the servicing node.
    The current obstacle is the ability to reliably/repeatably launch a modem test protocol from a browser interface such that results can be observed and/or recorded.
    I have had one phone call where the agent claimed modem errors, and a different phone call where the agent claimed no errors. This is not a reliable test.
    That is why I would like to know if there is an official Xfinity connection test that can be launched at will by a user that will show modem errors/issues.
    • Kitsap's avatar
      Kitsap
      Master
      The correctables/uncorrectables columns under the downstream bonded channels, reset to zero when you reboot your modem.
      Reboot your modem, let it run for a set time frame, such as a week, and download your values.  That is the best you are going to get for a repeatable at will test you can document.
      Your original post indicated a problem with a CM3000.  Now you are having problems with a CM2000?
    • FURRYe38's avatar
      The ISP will and may say anything to avoid taking the right action on getting this fixed. Not the first time.
      I bet if you take the CM2000 to a different location, might find a difference.
      Those errors in the event log which is what that is for points to issues ON the ISP side of the line. The tech only testing up to the building? How about from the building debarkation to your modem? Huh?
      If this is an apt building, then tech should have tested a bit more from the entry point in the building up to your modem.
      Something to check with maybe the XF thread on reddit. May find someone there that has more depth on what to test for on the ISP side.
      Good Luck.
    • DudeRides's avatar
      DudeRides
      Not yet. I have a new Xfinity gateway as well as a new CM3000. The current modem is a CM2000, not a 3000 (my mistake). I ordered a 3000 so I could get the latest/best tech in the design. I can log in to the CM2000 and see error messages in the log. When I call Xfinity to have them run a modem check I am told that no errors are showing in a remote diagnostic and a site visit is recommended. As mentioned above, I have had a site visit and the tech claims no issues on the line in.
      What I would like to do is find a way to trigger and observe a remote modem analysis, so I can see what the current CM2000 is being subjected to, then swap in the Xfinity Gateway and trigger the same, then possibly also swap in the CM3000 and trigger again the remote analysis. That way I can test all three environments. So far, I have been unable to find a way to consistently and interactively trigger a modem test.
      Anyone know how to do so?
      • FURRYe38's avatar
        What are the error messaged seen in on the CM2000?
        And last post you did with cable connections, saw lots of correctables and uncorrectables that should be mostly zeros.
        Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
        Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
        Be sure there are no coax cable line splitters in the between the modem and ISP service box.
        Be sure your using good quality RG6 coax cable up to the modem.
        Start with removing any amplifiers, signal attenuators, or splitters from the coax.
        From there check the line for kinks, damage, moisture in the line.
        Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
        Be sure to power OFF the modem for 1 minute then back ON.
        https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
        https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
        https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
        https://highspeed.tips/docsis-events/
        CM Modem Spectrum Analyzer: http://192.168.100.1:8080/
  • Do you need a screenshot of the entire page, scrolling the page, or only a particular spec or message?
    • FURRYe38's avatar
      You can copy the text data and paste it into your post.
      Images copy and paste isn't working currently.
      Lets check the signal and data first before doing anything else.
        DudeRides
        Downstream Bonded Channels
        Channel	Lock Status	Modulation	Channel ID	Frequency	Power	SNR	Correctables	Uncorrectables
        1	Locked	QAM256	20	525000000 Hz	7.2 dBmV	43.6 dB	1136	1242
        2	Locked	QAM256	1	405000000 Hz	6.4 dBmV	43.5 dB	2398	2922
        3	Locked	QAM256	2	411000000 Hz	6.9 dBmV	43.3 dB	2652	2858
        4	Locked	QAM256	3	417000000 Hz	6.8 dBmV	43.7 dB	2443	2824
        5	Locked	QAM256	4	423000000 Hz	6.7 dBmV	43.6 dB	2359	2673
        6	Locked	QAM256	5	429000000 Hz	6.9 dBmV	43.7 dB	2162	2658
        7	Locked	QAM256	6	435000000 Hz	6.9 dBmV	43.6 dB	2236	2520
        8	Locked	QAM256	7	441000000 Hz	6.5 dBmV	43.4 dB	1960	2564
        9	Locked	QAM256	8	447000000 Hz	6.4 dBmV	43.3 dB	2093	2479
        10	Locked	QAM256	9	453000000 Hz	6.5 dBmV	43.3 dB	2019	2425
        11	Locked	QAM256	10	459000000 Hz	6.6 dBmV	43.4 dB	2075	2329
        12	Locked	QAM256	11	465000000 Hz	6.6 dBmV	43.3 dB	1922	2372
        13	Locked	QAM256	12	471000000 Hz	6.5 dBmV	43.2 dB	1983	2311
        14	Locked	QAM256	13	477000000 Hz	6.5 dBmV	43.2 dB	1911	2360
        15	Locked	QAM256	14	483000000 Hz	6.6 dBmV	43.3 dB	1738	2150
        16	Locked	QAM256	15	489000000 Hz	6.6 dBmV	43.2 dB	1732	2161
        17	Locked	QAM256	16	495000000 Hz	6.6 dBmV	43.2 dB	1816	2092
        18	Locked	QAM256	17	507000000 Hz	7.1 dBmV	43.4 dB	1459	2016
        19	Locked	QAM256	18	513000000 Hz	7.5 dBmV	43.7 dB	1526	1906
        20	Locked	QAM256	19	519000000 Hz	7.4 dBmV	43.6 dB	1530	1806
        21	Locked	QAM256	21	531000000 Hz	7.2 dBmV	43.5 dB	1341	1752
        22	Locked	QAM256	22	537000000 Hz	6.8 dBmV	43.3 dB	1347	1694
        23	Locked	QAM256	23	543000000 Hz	6.2 dBmV	43.0 dB	1239	1780
        24	Locked	QAM256	24	549000000 Hz	5.6 dBmV	42.6 dB	1345	1689
        25	Locked	QAM256	25	555000000 Hz	5.5 dBmV	42.5 dB	1218	1625
        26	Locked	QAM256	26	561000000 Hz	5.8 dBmV	42.7 dB	1235	1560
        27	Locked	QAM256	27	567000000 Hz	6.3 dBmV	42.9 dB	1062	1631
        28	Locked	QAM256	28	573000000 Hz	6.4 dBmV	42.9 dB	1092	1527
        29	Locked	QAM256	29	579000000 Hz	6.3 dBmV	42.7 dB	966	1462
        30	Locked	QAM256	30	585000000 Hz	6.3 dBmV	42.7 dB	954	1434
        31	Locked	QAM256	31	591000000 Hz	6.5 dBmV	42.7 dB	961	1415
        32	Locked	QAM256	32	597000000 Hz	6.7 dBmV	42.8 dB	934	1380
        Upstream Bonded Channels
        Channel	Lock Status	US Channel Type	Channel ID	Symbol Rate	Frequency	Power
        1	Locked	ATDMA	5	1280 Ksym/sec	39600000 Hz	44.0 dBmV
        2	Locked	ATDMA	2	5120 Ksym/sec	29200000 Hz	46.5 dBmV
        3	Locked	ATDMA	3	5120 Ksym/sec	22800000 Hz	46.5 dBmV
        4	Locked	ATDMA	4	5120 Ksym/sec	16400000 Hz	46.5 dBmV
        5	Locked	ATDMA	1	5120 Ksym/sec	35600000 Hz	46.5 dBmV
        6	Not Locked	Unknown	0	0	0	0.0 dBmV
        7	Not Locked	Unknown	0	0	0	0.0 dBmV
        8	Not Locked	Unknown	0	0	0	0.0 dBmV
        Downstream OFDM Channels
        Channel	Lock Status	Profile ID	Channel ID	Frequency	Power	SNR / MER	Active Subcarrier
        Number Range	Unerrored
        Codewords	Correctable
        Codewords	Uncorrectable
        Codewords
        1	Locked	0 ,1 ,2 ,3	193	690000000 Hz	5.48 dBmV	41.8 dB	1228 ~ 2867	2921873759	1604952562	2848
        2	Not Locked	0	0	0 Hz	0 dBmV	0 dB	0 ~ 4095	0	0	0
        Upstream OFDMA Channels
        Channel	Lock Status	Modulation / Profile ID	Channel ID	Frequency	Power
        1	Not Locked	0	0	0 Hz	0 dBmV
  • FURRYe38's avatar
    Lets take a look at the modem signal and event log on from the modem.
    Please post a copy and paste of the modems connection status and event log page.
    https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
    https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
    ISP is known for making false claims so you'd get or rent something from them...
