alexwoolford's avatar
alexwoolford
add a third PLP2000 to a network
I have a pair of PLP2000 adaptors between my office and the router. They've been working pretty well for the last couple of months.   I also have a network printer in another part of the house wh...
  • michaelkenward's avatar
    Oct 25, 2018
    alexwoolford wrote:
    I called Netgear's technical support (agent 2490) who told me that these adaptors ONLY work in pairs and that I'd need two adaptors at the router in order to connect to both my office and my printer. According to the agent, if I wanted to connect three devices, I should have bought an extender instead.
    That is, to use a technical term, b*ll*cks.
    You can add more plugs to an existing network. I have done this many times.
    I currently run two networks with three plugs, sometimes more.
    The trick is to add each new plug one at a time.
    >>> Adding a powerline adapter to an existing powerline network <<<
    I find it best to introduce the new plug to the router plug in a nearby mains socket. Then I move the new plug to its intended location. It will remember the settings.
