vreynolds
Apr 28, 2017Luminary
Cannot factory reset Powerline 500 adapter
I got everything to work the first time, but mis-timed the security buttons, so I had to factory reset. I am able to factory reset the Powerline 500 WiFi access point, but not the PowerLine adapter. I held down the factory reset button with my dedicated factory reset paperclip (lol), but none of the lights change on the adapter.
I can definately feel the tactile button press, and held it down for 2 seconds, 3 seconds...etc. Still nothing, the power light remains a solid green, and nothing is being reset.
So now I have an access point which is reset to factory defaults, and the adapter which is not and they are not communicating with each other. Any ideas?
vreynolds wrote:I got everything to work the first time, but mis-timed the security buttons, so I had to factory reset. I am able to factory reset the Powerline 500 WiFi access point, but not the PowerLine adapter.
By "PowerLine adapter" I assume that you mean the plug connected to your router, the XAV5221. In reality there is no difference between the "host" plug and a "remote" plug. Some people buy the "wifi-less" bundle which has a pair of identical plugs without the access point feature.
Have you tried setting things up with the Netgear desktop genie as described in the Quick Start guide?
>>> XWNB5221 | Product | Support | NETGEAR <<<
Get the Genie here:
>>>> genie Landing Page | Apps | Discover | Home | NETGEAR <<<<
How do you know that the plug has not reset? I see no mention of flashing lights in the Quick Start guide.
Have you tried going through the setup process again?
1 Reply
Get the Genie here:
