Tyndinwa
Dec 14, 2017Aspirant
Cannot reset the wifi settings
I seemed to have lost the wifi extension from my AV200 powerline adapter. I have reset it (and the initial unit) and checked their encryption but using the Powerline Utility I keep getting a message ...
Tyndinwa
Dec 15, 2017Aspirant
Yes the router is product is the XAVN2001
It has run perfectly since I bought it - a couple of years at least, I think. Then I noticed that the wireless point in the room that I used was dropped so I have been trying to reset it without success. I have checked the system connection, completed a reset of all settings on the network I have, and in the utiliy it lets me select the unit and then select wireless configuration and whatever option I select, whether its plugged into the usual point or cabled to the PC, it returns an error message that the action cannot be completed ?
michaelkenward
Dec 15, 2017Guru - Experienced User
XAVN2001 is not a router. It is a Powerline Wireless-N Extender.
I still do not know what returns an error message "that the action cannot be completed".
Do you mean the Powerfline Utility? Which version?
What are you doing when you see that error?
- TyndinwaDec 15, 2017Aspirant
Yes, the Netgear Powerline utility D3.1.0.4 is what returns the error message and the message is 'Wireless setting fail' I get that error when I try to set up the wireless with security and change its name so as not leave it as an unsecured wireless point called Netgear.
