TmmyT
Jul 14, 2016Aspirant
Cloning and Network Security
Interesting forum. Okay so I have a non-netgear router. Right now I have the netgear as its own network so we have to log onto it. Can't use net genie because router is not netgear so can't put an...
VE6CGX
Jul 14, 2016Master
You will have to reconfigure the new router. What you are trying to do is like replaacing an engine on an Chevy with Ford engine....Setting up the router won't take that long.
- TmmyTJul 14, 2016Aspirant
I may have confused. I have a wifi router. Brought in a powerline adapater. Want to add powerline adapater to original router to have it cloned instead of making it a separate wifi network. The other questions remain. So i do not know what "new router" means in your post. Thank you.
- michaelkenwardJul 16, 2016Guru - Experienced User
Which powerline adapter?
Which router?
You might like to provide the answers to the questions suggested by the forum software.
(Include additional detail including model version, firmware, OS and environment where relevant.)
That makes it easier to cut to the chase.
