TmmyT
Jul 14, 2016Aspirant
Cloning and Network Security
Interesting forum. Okay so I have a non-netgear router. Right now I have the netgear as its own network so we have to log onto it. Can't use net genie because router is not netgear so can't put an...
TheEther
Jul 16, 2016Guru
TmmyT wrote:Interesting forum. Okay so I have a non-netgear router. Right now I have the netgear as its own network so we have to log onto it. Can't use net genie because router is not netgear so can't put any contols on the way it is set up currently. Or at least I haven't figured out how to.
I want to set up Powerline so it just clones my current wireless network, so we don't have to log on and off the two networks while working around the house, but I cannot figure out how.
You can clone your wireless network by logging into the Powerline and entering the same SSID and password as used on your non-netgear router. See page 16 in the manual (link).
My original wifi network is MAC whitelist protected. If I do clone it this way will I have to add the netgear device into my MAC whitelist on my original router. Will a cloned netgear also be MAC whitelist controlled for access. Meaning, will those who can get on original wifi network be the only ones to get on Netgear extended?
I believe the answer is no. The Powerline Wi-Fi does not have MAC whitelisting, so any device that has the Wi-Fi password can connect to the Netgear. If your original router applies MAC whitelisting to both LAN and WLAN devices (some only apply it WLAN), then non-whitelisted devices that manage to connect through the extender will probably not be able to get through the router, so you should still be protected.
TmmyT
Jul 18, 2016Aspirant
Thank you for this information.
