Claire2708
Dec 28, 2017Aspirant
Compatibility between PLW1000v2 and XAV5501
Hi, is it possible to connect to the Powerline AV+ 500 client adapters (XAV5001) to the PL1000 which is connected to my router? The PLW1000v2 kit was added to my network to create a Wlan access poi...
- Dec 30, 2017
Great, I managed to get the 500 plugs working :smileyvery-happy:
Thanks for all the help! I have also read the threads related to my specific topics and understand now much better how the Netgear adapters interoperate.
Happy new year and kind regards
Claudia
michaelkenward
Dec 30, 2017Guru - Experienced User
Claire2708 wrote:
Thanks. I assume that I have to reset the old 500 plug before I can reconfigure it to connect to the PL1000? As I configured the PLW1000 to take over the settings from my Fritzbox, I hope I do not loose any configuration made to my PLW1000 set.
You may not need to reset the plugs. Just following the instructions I linked to might be enough. I can't see that adding a plug will do anything to the PLW1000's settings. You won't be going anywhere near that plug.
In case I would like to replace my old 500 plugs, which can/should I use? I
You can add any plugs you like so long as they are AV compliant, which should cover anything sold now.
The 1200 plugs should be just fine. They also have 1000 Mbps Ethernet. The slightly different operating speeds is barely noticeable in comparison with the 500 to 1000 jump.
You don't even have to buy Netgear plugs, but I find it easier to stick to the same brand. Then you can use the same software to set up and control them.
Claire2708
Dec 30, 2017Aspirant
Claudia
