Carterlil21
Mar 09, 2017Aspirant
Constant connection speed drops on 1200 powerline
I've purchased myself a 1200 powerline to connect my desktop computer to the Ethernet. This desktop computer is one floor up and maybe 20m north of the router. Not too far between the two powerline un...
- Apr 09, 2017
Hi Carterlil21,
Are devices getting valid IP address when connected to the adapter? If yes, what is the IP address?
Try bringing the 2nd adapter closer to the 1st adapter and check if the same problem.
JamesGL
Mar 22, 2017NETGEAR Employee Retired
Hi Carterlil21,
Try connecting the two plugs on same room with the router. Check and observe the speed. If it did not drop, then the issue is with the distance.
JamesGL
Mar 30, 2017NETGEAR Employee Retired
Hi Carterlil21,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- Carterlil21Apr 01, 2017Aspirant
That problem was fixed with a full factory reset, but I am now facing another problem. While using my computer, the internet connection just dropped. Internet still works on other devices. I unplugged the ethernet cable from my computer and plugged it back in, unplugged the powerline box from the wall and plugged it back in, restarted my computer, factory reset both of my powerline boxes, reset my modum and still nothing.
Its not my computer thats the problem. I have plugged my laptop into the ethernet cable as well and it doesnt work.
All the lights on the powerline are lit and solid green, but its just not working.
This product has just been problem affter problem.
Im not pleased.
- JamesGLApr 09, 2017NETGEAR Employee Retired
Hi Carterlil21,
- JamesGLApr 13, 2017NETGEAR Employee Retired
Hi Carterlil21,
Any update regarding your issue? Looking forward for your feedback.
