Retired_Member
Apr 11, 2023Error login into www.mywifiext.com.
Hi, I have a PowerLINE 1000 + WiFi (PLW1000). I changed the password of my Access Point (128 characters long), with the possibility of recovering the password, by answering the two security question...
- Apr 11, 2023
to long of a password to log into it.
Apr 11, 2023Guru - Experienced User
Maybe try factory resetting and doing a shorter 8-10 character password
- Retired_MemberApr 11, 2023
Factory resetting is the last chance. If I can, I would like to resolve this problem not factory resetting.
- plemansApr 11, 2023Guru - Experienced User
tough to get in and access it if the password is the issue.
Password recovery just gives you the password but thats the problem.
Ok, thanks.
In your opinion, what is it due to?
