Retired_Member
Apr 11, 2023Error login into www.mywifiext.com.
Hi, I have a PowerLINE 1000 + WiFi (PLW1000). I changed the password of my Access Point (128 characters long), with the possibility of recovering the password, by answering the two security question...
- Apr 11, 2023
to long of a password to log into it.
Apr 11, 2023Guru - Experienced User
Maybe try factory resetting and doing a shorter 8-10 character password
Retired_Member
Apr 11, 2023Factory resetting is the last chance. If I can, I would like to resolve this problem not factory resetting.
- plemansApr 11, 2023Guru - Experienced User
tough to get in and access it if the password is the issue.
Password recovery just gives you the password but thats the problem.
- Retired_MemberApr 11, 2023
Ok, thanks.
In your opinion, what is it due to?- plemansApr 11, 2023Guru - Experienced User
