hangz
Dec 06, 2015Follower
is Powerline 500 compatible with powerline 1200?
Dear sir
I am using powerline 1200 package in my home. But now i need something can provide both ethernet and wifi. Can i buy powerline 500+wifi, plug in other room? Is it compatible with the powerline 1200 i am using?
It's my understanding that all Homeplug AV and AV2 products are compatible. A Powerline 500 product, however, may drag down the speed of the Powerline 1200 adapters.
Another option is to buy another Powerline 1200 adapter along with a separate range extender. This will insure that you don't compromise the speed of your Powerline network.
- randomnut1Apprentice
You can mix them yes but your adapters will only be as fast as the slowest device in the network.
A way around this would be to pair the 1200s together with one network name and the 500s together under a different network name.
