Mauro12's avatar
Mauro12
netgear dg834g v4
Hi everyone!
I’m trying to get my 2 Tplink powerline connected to my Netgear router but I’m not having any luck
Please help me
  • michaelkenward's avatar
    michaelkenward
    What's the problem?
    The DG834Gv4 is 10 years old, with slow Ethernet ports, but it should work.
    Plug powerline LAN into router. Follow the instructions for your powerline devices.
    • Mauro12's avatar
      Mauro12
      Thank you for the reply.
      I pluged in the powerline attached the Ethernet cable from router to the first power line and got the green lights but I haven’t got any internet
        michaelkenward
        What have you connected to the second plug?
        As you are dealing with Tplink, you might want to seek their advice. The router is just chucking out the LAN. Setting up your Powerline devices to work with that may not be the same as using Netgear plugs..
