surfjabroni1
Aug 31, 2015Follower
Newbie on powerline 500 additional devices
Hi everyone, I have the NETGEAR Powerline 500 + N300 WiFi and 1 Port Starter Kit (XWNB5201) set up to a wired connection on an apple TV device downstairs in my home. Now I want to make a wired connec...
- Sep 01, 2015
If the Mac upstairs is on the same electrical circuit as the powerline kit, then wireless does not have to come into it.
I have the same setup with the XWNB5201. I have added all manner of different plugs to it. They don't have to be the same speed, or even the same make.
At the moment I have a XAVB5201 pair. But that is one of many Netgear bundles that force you to buy a pair of plugs. The XAVB5421 pass through plug comes as a single. If you think you might need an extra network socket, there may be one available with a pair of LAN outputs.
michaelkenward
Sep 01, 2015Guru - Experienced User
