adamsabri's avatar
adamsabri
PL1000 Ethernet adapter not working saying Unidentified connection
Hey, for the past few weeks, my ethernet isn't working. It connects then says unidentified network and no internet access. I tried to reinstall the ethernet driver and restart pc but stil doesnt't work. Please help me ASAP
  • michaelkenward's avatar
    michaelkenward
    Sounds like a Windows thing. If it thinks you are on a public network it will block access.
    Check the Network & Internet settings.
    Then Change Connection Properties. You want Private.
    • adamsabri's avatar
      adamsabri
      Hello thank you for replying. I tried to do what you said but it didnt give me the option because it hasnt connected to it fully (becuase it says unidentified network). I tried to diagnose the problem and it said No ip can be found. I have this software called hamachi and I am not sure if that is whats causing the problem.
        michaelkenward
        I have no idea what that is.
        Try the Windows network troubleshooter.
        I assume that you have checked that the LAN cable is properly plugged in.
