ayozdob's avatar
ayozdob
PL1000 Pick-A-Plug LED off throughout the house
Title. My PC and router are connected to ethernet cables connected to the PL1000. Last night, suddenly, both stopped functioning and the Pick-A-Plug light has gone off on both. What can I do to fix this? I have tried factory resetting and changing the location of the plug.
  • plemans's avatar
    do the plugs work in the same room?
    Reason I ask is many things interfer with powerline. A device going bad can inject a lot of interference in the powerline system.
    If they're in the same room, thats where they'll get the best connection.
    • ayozdob's avatar
      ayozdob
      No, however they also dont work individually. Because of the setup of the house, they cant be in the same room. They also don't work when one is disconnected.
      • plemans's avatar
        ayozdob wrote:
        No, however they also dont work individually. Because of the setup of the house, they cant be in the same room.---its for testing to see if they work. having them on the same circuit is an attempt to remove as much interference as possilble.  They also don't work when one is disconnected.
