clithes
Aug 15, 2015Prodigy
PL1200 and PLP1200 Powerline Utility / Netgear Genie issues
While we are waiting for Netgear to update their Genie and Powerline Utility to correctly recognise their new PL1200 and PLP1200 powerline adapters, the support software for Zyxel's version of these ...
- Aug 29, 2015Thanks for the tip, works great.
grimmace
Oct 30, 2015Apprentice
Great news! The recent update to Genie, 2.4.16, sees and and allows the PL1200's to be changed. On the network map switch to the powerline view. You can see connection speeds, update PL1200 names, and set the security code. So far so good.
- randomnut1Nov 17, 2015Apprentice
Thanks for the tip to find powerline info in Genie. There doesn't appear to be any firmware update option in Genie that I can see. Is there another way to update the PL1200?
- grimmaceNov 17, 2015Apprentice
There is no firmware upgrade that I know of. I meant exactly what I said, you can update the names of the devices, that's it. Sorry for any confusion.
