loveall27's avatar
loveall27
PLP 2000 and adding additional PLP1200
I have two PLP2000 and both are working fine. Pick a plug LEd light is solid green (Means throughput is more than 80 mbps).  Now I bought additional two PLP1200 and when I added this PLP1200 then pick a plug light on the PLP2000 turns red , as per the manual if pick a light led is red then throughput will be between 50 mbps and 80 mbps.
My question is if both models are gigabit capable then why throughput falls below 80 mbps when I add PLP1200?  Should I get all four adapters to  PLP1200?
