paulzila
Jan 18, 2016Aspirant
PLP1200 Basic Questions
I purchased my first PLP1200 kit and it seems to be working well. One adapter connected to FIOS modem; One adapter connected to PC on the opposite side of the house. Wifi connection to this PC has be...
- Jan 20, 2016
Hi paulzila,
1.) You can use the kit as new adapters for your devices. You can only use one adapter connected to the router and the rest will be the receivers.
2.) If you have set up the security protocol already you can just press again the security button on the 1st powerline then press the button on your new powerlines.
3.) I am not sure what security you are referring for WiFi since the adapters are used for wired devices.
JamesGL
Jan 20, 2016Master
Hi paulzila,
