JBSF
May 28, 2016Aspirant
PLP1200 powerline PLUS PLW1000 or 1010?
I have installed a PLP1200 kit and it works great to get ethernet up to an upstairs office in a brick home, from a downstairs room with a Comcast Arris wireless cable modem router. This system replaces a now-dead (surge from lightning strike) original XE(?)102(?) powerline kit.
Now, I'd like to get fast internet into another upstairs room.
I'm considering buying another PLP1200 kit ($79) but I only need one more unit, so I'd have an extra one. Do/Will Netgear soon sell single units separately?
It occurs to me that I might want to do powerline wireless instead in the second upstairs room, in order to have an ethernet port and, in addition, a wireless signal up there for phones as well as laptops. I found Negear powerline wireless kits plw1000 and PLW1010, which appear to be the same.. Are PLW1000/1010 units compatible on the same power lines with the plp1200 units I have already installed?
If compatible, are they a slower powerline standard, and will they slow down the service to the upstairs PLP1200 unit due to a "slowest link" compatiblilty issue? (I'm not worried about bandwidth and simulaneous usage, just slowing down the nice speed I already have with the powerline.)
If compatible on the same power lines, do they use the same communications protocols, i.e. will I need to install both ends of the PLW1000/1010 kit, or might the existing PLP1200 unit downstairs attached to the cable modem router communicate effectively"driving" a new PLW1000/1010 receiving (and wireless rebroadcasting) unit upstairs, working with the signal that is already on the electric line from the PLP1200?
Thanks for any knowledge. Cant find it in Netgear sites (which describe compatibility with older gear), or Amazon or Newegg answered questions.
JBSF wrote:Do/Will Netgear soon sell single units separately?
This is a constant refrain. People dislike the idea of buying pairs when they need single units.
The response is usually to go find a compatible single unit, regardless of who makes it.
These things work to industry standards. Find one that claims to be of the same "AV" standard as the ones you have and just add it to the circuit.
I have successfully combined different hardware of different speed standards and it works. Of course, if you add a slow plug, then some of the network will work at its standard. (I'm afraid I haven't seen a definitive answer as to how much of the network will slow down.) So find something that is as fast as, or faster then, what you have now.
- JBSFAspirant
Thanks for the suggestion. Netgear product specs state that the wireless transmitter PLW1000 works to a 1000bps standard, while the PLP1200 powerline is a 1200bps standard. Both are "Homeplug AV2 compliant," which I guess means they will work on the same powerlines. Still wondering if I would need to install BOTH transmitters in the downstairs office, in order for each of the slightly dissimilar units to work in different rooms upstairs, or if the PLP1200 powerline signal will also send a compatible / suficient signal to the PLW1000 ethernet plus wireless transmitter that I want to install in a second upstairs room.
I am a bit confused by your reference to two "transmitters".
Only the PLW1000 us a transmitter in the sense that most of us understand it. It is a wifi transmitter/receiver as well as a powerline plug.
The PLP1200 is just a powerline plug. It doesn't do much in the way of transmitting in the conventional wifi sense. It just sits on the network exchanging information with other plugs on the mains LAN.
The PLW1000 will also take part in this LAN exchange but it also has the added ability to handle wifi.
All of these plugs will take part in the "over the mains" data exchange that comes out of the powerline plug that is attached to your modem/router. The PLW1000 doesn't depend on anything from the PLP1200, beyond handling stuff that is connected to it.
The 1000 and 1200 thing are solely related to the LAN speed over the mains circuit. They have nothing to do with wifi speeds.
Just stick the PLW1000 in the room where you want to provide wifi and away you go.
Things will work at the 1000 speed, but I bet you won't notice any difference.
