jdrewf
Jun 25, 2018Initiate
PLP2000 second adpter
I am looking at the PLP2000 powerline kit and I am interested in a second adapter, not the whole kit just the receiver is an additional adapter available
Nico9275
Jul 30, 2018Aspirant
Which model could be compatible with PLP2000 without loosing the benefit of its speed?
michaelkenward
Jul 30, 2018Guru - Experienced User
Any plug with the same, or better, standard.
- Nico9275Jul 30, 2018Aspirant
Thanks, last question, the software NETGEAR Powerline Utility doesn't work anymore with my PLP2000 - any chance to have a similar software for my PLP2000?
- michaelkenwardJul 30, 2018Guru - Experienced User
Netgear seems to have abandoned its powerline utility. Some of us use the ZyXEL alternative as a substitute.
Netgear Powerline 1000 - NETGEAR Communities
Solved: Netgear Powerline Utility for Windows - NETGEAR Communities
PL1200 and PLP1200 Powerline Utility / Netgear Gen... - NETGEAR Communities
