JessQ's avatar
JessQ
PLW 1000 - Connecting other networks to mine - MASSIVE SECURITY RISK
I live in a condo/appartment block. I bought the powerline adapter and connected it to my network. When checking the ISP Modem, I can see other ISP Modems on my network, through the port where the Powerline adapter is attached to. I have followed this article:
https://kb.netgear.com/29923/Changing-the-DST-network-encryption-key
To change my encryption key to make sure it wasn't the lack of encryption. I have also turned of the Wireless component as I do not need this. I am still pulling other peoples networks!
When I release and renew my IP configuration, I am given a Private network address, with the Gateway of another Modem!!!
Please help! I work from home and this is major risk for me!
  • michaelkenward's avatar
    michaelkenward
    What do you mean "pulling other peoples networks"? You can see their wifi? You can see them on the wired LAN network?
    I don't know about anyone else, but this looks more like the rest of the people on the network should worry, not you.
    You may be able to see them, but can they see you?
    What else is on your network? Router? Modem?
    • JessQ's avatar
      JessQ
      By 'Pulling other people's networks' I mean, I can see their router's/modems on my network. When I ipconfig /release | ipconfig /renew I am able to connect to their network, but still using the name of my wifi. I can also see their devices on my network when running a scan using Advanced IP Scanner.
      If I can see them, connect to their modem's and get to their modem's gateway address', I'm pretty sure they can see me.
      On my network, I have my ISP's modem/router which connects to the Netgear device, and then the other netgear device on the other side of my apartment. There are no other devices.
        michaelkenward
        I see no answer to these questions:
        Any evidence that they can see you? "Pretty sure" won't stand up in court.
        What happens if you remove the Powerline plug from the network?
        JessQ wrote:
        On my network, I have my ISP's modem/router ....
        Yes, but what is it?
