natbrux's avatar
natbrux
Follower
May 25, 2016
PLW1000 as repeater?
Is it possible to set up the PLW1000 as a repeater?  Instead of having 2 networks with the same name?  I can't find an option for this in the settings section.  I used WPS to copy the settings from my wireless router, hoping that would make it function as a repeater.  Now I just have a second network option (netgear, netgear_2GEXT), which also requires me to log in with a password. I'd just like to know if it's possible to set it as a repeater so I have one network option and don't need to log into the other one separately if I'm in the opposite side of the house?  Thanks
    I bought it and connected as in the photo, it's working.
    • ErikRoss's avatar
      ErikRoss
      JamesGL
      I think that is not necessary open another topic for my question so i write here.
      I have read  yours information on product,  and I want buy this: Netgear PLW1000-100PES AC650 WiFi .
      I want know, if  it's  possible connect the device inverted, not at the same mode of the page 7 of your link instruction, (Titled : install yours adapters).
      http://www.downloads.netgear.com/files/GDC/PLW1000/PLW1000_FullIG_17Sept2015.pdf?cid=gwmng
      But,  connect the wifi module to the router whit ehternet cable, and next module (whitout wifi) to the  other device (PS4 - Pc) whit cable.
      Thanks for attention.
      • JamesGL's avatar
        JamesGL
        NETGEAR Employee Retired
        Hi ErikRoss,
        The PLW1000 has an ethernet port. You can use it for Wired devices and for wireless devices.
  • JamesGL's avatar
    JamesGL
    Hi natbrux,
    We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
    If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
