goss1000
Jul 12, 2016Aspirant
Powerline 1000 and 1200 serie
Hi Is there realy a speed difference between PL1200 and PL1000? Can someboby explain me the difference? accordind to the spec sheet, they are both identical. One more question, Can we buy only th...
clithes
Jul 17, 2016Prodigy
I doubt if there's much 'real world' difference between a 1000 and a 1200. To answer your second point, Netgear don't seem to offer solo units for purchase. You may be able to pick one up second hand on it's own, but thats probably your best option.
Hope this helps
CAL-TN
Nov 28, 2016Tutor
I have the Powerline WiFi 1000 with one adapter connected to modem and one access point device. Works fine. However, I want to add another access point device in another part of my home. I just left BestBuy and no one there had a clue. I ended up buying a Netgear WiFi Range Extender EX6100 because it "looks like" the access point device that came with my PLW1000 kit. Did I buy the right device? If not, what do I need to buy? Second question: I think the password is associated with the access point device, so I fear my second access point device will come with a different password - can I change the password or will I have to live with two diff passwords? Thanks
