Tony3031's avatar
Tony3031
Follower
Sep 19, 2018
Powerline 1200 stopped working - Pick A Plug LED alternating between green and red
powerline was working for me for about a month before I started getting the red light indicator and network speeds slowed & became comparable to my normal wifi. i have one connected upstairs to my ro...
  • Blanca_O's avatar
    Sep 23, 2018
    Hi Tony3031,
    Welcome to NETGEAR Community!
    The Pick A Plug feature lets you pick the electrical outlet with the strongest performance, indicated by the color displayed by the LED:
    Red. Link rate < 50 Mbps (good).
    Amber. Link rate > 50 and < 80 Mbps (better).
    Green. Link rate > 80 Mbps (best).
    Off. The adapter did not find any other compatible PowerLINE devices using the same encryption key.
    Was there any changes on your setup? We also need to consider the number of appliances turned on.
    You may want to check this reference link : https://kb.netgear.com/20233/
    Blanca
    Community Team
