glennv
Nov 05, 2016Follower
powerline 1200
Hi, is it possible to buy a single powerline 1200? the shops in belgium only sell a starterskit. if not so, is there any other powerline that can communicate with the netgear pl1200?
michaelkenward
Nov 06, 2016Guru - Experienced User
Netgear, like most suppliers, deals only in twin packs.
If you can find a seller that makes singeltons, then is it uses the AV standard, it should work with the Netgear plugs. (Check out "av1200 powerline" on Google.)
One fly in the ointment, a powerline network operates at the speed of the slowest devices. So add an AV500 to your 1200 Mbps, and the AV500 calls the shots at 500 Mbps.
