Wernyhora's avatar
Wernyhora
Follower
Aug 06, 2017
Powerline AV500 not working on iMac OS Sierra
Hi guys,
I am a new owner of my first Apple and since yesterday I am not able to conect with my network via ethernet via Powerline adapter.
The only issue I have is that my iMac can see the network but is not able to conect with Internet.
My status is: connected (IPv4: using DHCP) plus description: "Ethernet itself has an assigned IP address and can not connect to the Internet"
I was trying everything with restarting my router, all adapters.
I don't know if iMac is connected with adapters or with my DSL router.
Maybe I should change the IPv4 configuration and use other options: DHCP with manual IP, or manual.
This is ironic because I have WiFi connection directly with my DSL router but the signal is poor.
That was the main reason why I have bought the Powerline adapters.
Have anyone had problem like this?
I desperately need a solution !!!
Thanks for any tip ;)
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Did you have the Powerline stuff working before you went for the Mac?
    The Powerline device does not control IP addresses, that is down to the modem/router. That is probably a good place to look for solutions.
    That makes sense if the Mac insists on using a particular IP address. Can you troubleshoot by using a direct LAN connection to the router? That will confirm if this is a Powerline problem or down to a fight between the Mac and the router.
