sunnyhouse1's avatar
sunnyhouse1
Powerline AV5001 not showing on the Netgear utility(sam)
I reset the powerline Av500 to factory setting then installed the powerline utility v2.0.0.8 on my new pc. when I ran the utilty application,it found the device but says "unknown" with the lock icon locked so i can't set it up or change anything. All the light is running correctly on the adapter.
