mccauliflower
Jun 06, 2016Aspirant
Powerline Networking won't allow simultaneous wired and wireless connections
So I've got one Powerline adapter connected to my modem (room 1) and the second powerline adapter connected to my router (room 2). Wi-Fi works great. Here's the issue: I'd like to be able to plug my ...
- Jun 09, 2016
Hi mccauliflower,
Is your modem a modem/router or just a plain modem? If it is just a plain modem, then your setup will not work. The problem with that kind of setup is that the modem will only recognize one connection at a time. If the router gets the connection first via the 2nd powerline then the laptop wired to the 1st powerline with the modem will not be able to get a connection. This is a modem limitation. If you happen to have a modem/router type of modem, then it should work as it caters 2 or more connection at the same time.
michaelkenward
Jun 07, 2016Guru - Experienced User
mccauliflower wrote:Perhaps the "wonkiness" of my arrangement (which, I should repeat, works great for Wi-Fi in room 2) is keeping me from enjoying a wired connection in room 1. Would you agree? Or do you think there might still be a way to plug into the powerline in room 1?
That seems likely to me. But I am no real expert.
I do, though, have a similar dilemma. My modem/router is well away from many of the wifi clients. My solution is to have a powerline arrangement that has two powerline plugs (well, several actually) but one of them is also a wifi extender. an XWNB5201. This provides the wifi access to those "remote" devices.
As it is, I can't see any reason why you need the powerline plugs, unless this is providing you with the link between the modem and the router.
If this is the case then I would worry about which box is handing out the IP addresses for local devices, wifi and wired. In other words, which is the DHCP server? They can't both be doing it. At least, they shouldn't. If they are this might explain what you see.
If you put the modem and router together, this would deliver wifi in room 1. Then an extender would feed off the mains LAN and provide wifi in room 2.
I suspect that you will find that this is a more normal configuration.
JamesGL
Jun 09, 2016NETGEAR Employee Retired
Hi mccauliflower,
- michaelkenwardJun 10, 2016Guru - Experienced User
Or do what everyone else does. (See above.)
Put the router next to the modem.
Plug the Powerline into the router.
Put the other Powerline in the other room and use that to feed a wifi extender/repeater.
Or, probably the cheapest, get a powerline plug that also acts as a wifi extender.
- mccauliflowerJun 10, 2016Aspirant
Thanks, Michael.
I've tried the standard Powerline arrangement (modem to router to powerline) but the Wi-Fi doesn't reach room2. That's why I do the wonky thing.
You're right about the Wi-Fi-enabled powerline solution -- if I were to buy one of those, that would probably resolve everything.
Thanks again.
mccauliflower wrote:I've tried the standard Powerline arrangement (modem to router to powerline) but the Wi-Fi doesn't reach room2.
That's why I suggest the wifi extender. It is designed for that need.
