ddregs
Dec 02, 2015Aspirant
Problem with XAVB5221 - cannot make it work
Hi all, I am asking for support here in order to install and configure my newly bought Powerline XAVB5221 What happens is the following scenario: as soon as I connect the 2 XAVB5221 , one to the r...
Babylon5
Dec 02, 2015NETGEAR Employee Retired
It doesn’t seem like you are doing anything particularly unusual and your configuration should work.
I’m guessing that this could possibly be a hardware fault with the Powerline products, in which case you could perhaps test them out at a different location e.g. a friend or relative’s house. Otherwise maybe an issue with your house wiring e.g. a faulty earth connection at one of the sockets or part of the circuit, you could try using other sockets / rooms as a test, or buy a socket tester for a few £’s.
The only technical issue that I could imagine might be a possibility is that you have somehow created a network loop?
http://www.dummies.com/how-to/content/effect-of-a-network-loop.html
- ddregsDec 02, 2015Aspirant
No network loops are present, unfortunately.
I simplified the network to do the tests, since my house has 4 switches (1 GS608 and 3 GS605), 1 Powerline XAVB2101-100PES, and several devices connected (decoders, tvs, pcs, access points, tablets, smartphones, nas), and in the configuration used for XAVB5221 installation I just had router connected via ADSL, the NAS, 1 PC connected via cable, 1 GS605 switch connected via cat 6 ethernet cable to the router and 1 powerline XAVB2101 to the switch.
So far, I'm pretty sure no network loops are there in this simplified configuration.
Thanks for your suggestions though. :-)
