Sigo
May 31, 2017Aspirant
Setting up old router (N750/DGND4000) to use as wireless access point
I have aPowerline AV 500 set up, Pass through adapter (XAV4501) and WiFi Access point (XWN5001). It works brilliantly. I wish to extend the reach by adding another similar access point, but Netgear...
Sigo
Thank you for prompt response, but I said I was a bit of a dunce.
DHCP, disconnect it...errr?
Subnet, static IP address??...I'm really struggling with 2.
If I make it to 3. do I leave the connection via the LAN ports permenantly connected, the new access point is some 50 metres away although on the same circuit.
I'm really sorry, I need the ABC, if only 'Dummies for setting up a wireless access point via an old router' existed. I might need to call in an expert.
Thanks again The Ether, much appreciated, at least I know it's a universal solution, once I've cracked the terminology maybe I'll succeed.
TheEther
Jun 01, 2017Guru
Perhaps this CNET article will help. The article is missing an important step. Between steps 2 and 3 there should be an additional step to change router A's IP range: 192.168.1.2. through 192.168.1.254. It should be changed to 192.168.1.3 through 192.168.1.254. This frees up 192.168.1.2 to be used by router B.
- SigoJun 01, 2017Aspirant
Thank you again. I'm away from home for a few days so will try again when back. A quick glance through the article tells me this should be relatively unchallenging to follow. Appreciate it.
- SigoJun 12, 2017Aspirant
Sorry not been back, away then ill. Tried this morning. I can't even get into the router's Access Point via ethernet cable to a LAn port...put in its IP address all it said was 'not connected to the internet'! Followed Mac instructions - no green dot showing connection. Am I being utterly dim, or is there something I'm missing in the router's set up/settings? In spite of your kind help, I'm in despair, if I can't even get into the settings, then there's not much hope for doing the more complex stuff. Durr...
- TheEtherJun 12, 2017Guru
What IP address did you use to connect to the router? Did you follow the instructions in the article to determine the router's IP address?
