nball12
Aug 30, 2016Follower
Using powerline adapter with router
I want to use my PLW1000 powerline adapter with a second router on my network. The router im trying to use is a linksys wrt120n. I have to cat5 from the powerline adapter hooked into the internet port on the router. Thanks for any help in advance!
- It sounds like you have the wiring worked out. What other help do you need? What are you planning to use the second router for?
...and a network map would help.
What is connected to what?
