jbousaba
Sep 19, 2018Aspirant
Utility for PLP2000
Hi, I just bought the powerline PLP2000 devices, does anybody know if there is a utility similar to the one the AV500 series has? So far I have not been able to find one, which is a bit disappointing. thx.
1 Reply
Netgear seems to have dropped the ball on that one.
You can get at the Powerline device using the standard desktop genie, but for other things people use the ZyXel equivalent of the older utility.
Netgear Powerline 1000 - NETGEAR Communities
Solved: Netgear Powerline Utility for Windows - NETGEAR Communities
PL1200 and PLP1200 Powerline Utility / Netgear Gen... - NETGEAR Communities
