laurentroger
Dec 02, 2015Aspirant
XAV5421 Problem
Hi,
I bought several and they XAV5421 It Works fine for a certain time. After a time of a powerline began to no longer function on an IP in particular my LAN. Even after reset nothing works. So I decided to buy more to see if the first was not defective. Still the same problem after a certain time a particular IP is blocked.
I tried to seek technical assistance on your site but no serial numbers are recognized....
What can I do ? Is there a technique tip?
PS: Just to point out that I'm back to 200 powerline and they work very well, them ...
- JamesGLNETGEAR Employee Retired
Hi laurentroger,
What are the IP addresses that are blocked when using the XAV5421?
Do you get the same IP addresses with the 200 powerline?
- laurentrogerAspirant
Hi,
For example 192.168.1.121 and it is a static ip (no DHCP) so it's the same with 200 powerline.
regards
When no connection with the XAV5421, can you still ping websites or even ping the default gateway?
