tisina's avatar
tisina
Follower
Aug 06, 2017
xav5601 rebooting / firmware???
Hi,
I have problem with xav5601 powerline adapters, one of them after working some short time start to auto reboot, for me look like that is problem and simple don`t want to stop until I remove it from power socket...
Also, I try to upgrade firmware but look like don`t exist firmware, you have bad tool for firmware upgdate on page for this device, tool is for xav5501....this is not good!!!
I need solution...
Thanks.
1 Reply
  • No firmware available for this model.
    I have the same problem (re-booting restart conneciton interruption no network yigh).
    I read somewhere small packets is the problem for Firware version v0.2.0.7CE
    Currently working for me by using a fake QOS setting.
    Use "Powerline Utility" set the QOS of device near PC to use MAC of other device and priority HIGH.
    So far so good .... weird.
    If it stops working I will update.
