fullyZ's avatar
fullyZ
Novice
Jun 29, 2013
802.11n symbol with A6200
I was wondering if there is a particular symbol for 802.11ac connection in windows...
I can connect up to 866.5Mbps but windows is still showing 802.11n is it normal?
  • I just bought mine from Best Buy today, installed it. And it still says 802.11n..... a bit frustrating. I am connected at 468.0 Mbps. I am currently looking at my Wi-Fi Status.
    If this doesn't say 802.11 ac by Friday, then I am returning it back to Best Buy.
    Luke
    Luke
    What tool are you using to look at your wifi status?
  • Retired_Member's avatar
    Retired_Member
    If it makes you feel any better I'm using the Intel AC7260 and nothing I found so far denotes the connection as AC. INSSIDER shows my max connection at 450, I connect @866.7 all day long.
  • Sorry for the late reply... i was looking in the wifi status.. to me it connects up to 900 and stuff but performances are a joke, im coming from a 300Mbps adapter and my transfer rate in MB/s is the same.
    I've already tried 100 different HDD with all the possible file systems, USB3.0 doesnt change anything (as it should be).
    To get descent speed and consistent link speeds, I had to flash my router to an older version, from R6300-V1.0.2.68_1.0.49 to R6300-V1.0.2.38_1.0.33. It didn't matter what adapter I used, A6200 (2 different ones), WNDR4100, AE3000, or the AE2500.
    See this thread:
    http://forum1.netgear.com/showthread.php?t=87143
