viper37
Jan 18, 2015Follower
A6200 adapter stopped working
Hello,
First, my system specs:
http://pastebin.com/Kdf7871e
My problem:
As the title says, my adapter stopped working (after roughly 8 months of faithful services). Friday evening, I had a message from Windows (8.1), asking me to reboot to finish the installation of some updates. Upon reboot, my adapter wasn't working, but I managed to repair the connection by disabling and re-enabling the adapter in Device manager. Then I tried to install another update, it failed, I rebooted, and voilà, no more internet connection.
So, I tried uninstalling the drivers, re-install the lastest version (.35 - standalone). Still not working.
I uninstalled the driver, I used Ccleaner to clean my registry, I reinstalled the 0.26 version (standalone) of the driver, no luck.
I brought the adapter to another Windows 8.1 machine (AMD based, this one though), installed the 0.35 drivers and it worked fine on the first attempt. This machine also has all the latests Windows updates installed.
So, tried something more. Reinstalled all up-to-date drivers on my machine, still no luck. I uninstalled the Netgear drivers, then I used Revo Uninstaller Pro to reinstall them, so it could monitor the install, then used the uninstall function to help me purge the registry. Then I reinstalled the 0.35 drivers. No luck.
And then I decided it was time to be a man, admit I am baffled and cry for help ;)
If I got into the Device manager, there's yellow triangle next to my adapter and the error message when I right-click properties:
This device is not working properly because Windows cannot load the drivers required for this device. (Code 31)
{Operation Failed}
The requested operation was unsuccessful.
So far the only thing I haven't tried is to uninstall all the latests Windows Updates... I'll do it if there's no other solution, but I thought that maybe there was some cleaning utility, akin to the ones used for video card drivers, that I could use?
Thanks for the help,
- kingwAspirant
I'm experiencing this same issue.
Have you managed to resolve it?
After reinstalling the driver a few times it starts working, but once i reboot my PC i get the error again.
Using the latest driver standalone 1.0.0.26 on Windows 8.1
- kingwAspirant
After scouring the internet for any kind of solution I could find, the following worked for me and seems to have persisted through a reboot.
1. Plug in Netgear A6200
2. Install the driver (I used A6200-V1.0.0.26-1_Software-version/standalone-V1.0.011-win8.1_win10_signed)
3. Open the Registry (regedit), export a copy of HKEY_LOCAL_MACHINE/SYSTEM/CuurentControlSet/Control/Network (File->Export) *This is a backup*
4. Delete the key HKEY_LOCAL_MACHINE/SYSTEM/CuurentControlSet/Control/Network/Config
5. Open Device Manager and Select the Netgear device and uninstall the driver, (I selected delete driver files)
6. Restart the PC
7. Open Device Manager select the Netgear Device (It should be under a different tab now) and update driver software (point it to your prior driver installation)
