CptCrunch's avatar
CptCrunch
Follower
Oct 12, 2012
A6200 Experience
Bought the A6200 from Best Buy about 2 weeks ago. I wish I had a great experience normally I speak very highly of Netgear and its products this one is not the case what so ever.
I have decent speeds since I am connected to a N600 connection but it doesnt last long what so ever. After about 10 mins of any file transfer it will go instantly into Limited or No Connectivity. I have tried every troubleshooting step known with no luck what so ever. The only way that I have found to fix the issue is to do a full reboot of Windows 7 and then it works. Logging Out of Profile and Re-Logining in does not wor. Disable, Re-Enable device hangs. Using the Software provided also fails. I have reinstalled Windows, I have returned the Product and tried yet again and still same results. I have even borrowed a friends router and still the same.
I feel as if I am the only one with this issue, when will the next set of drivers for this A6200 be released?
  • Same thing is happening with me once I upgraded...
    I only got a problem since a did upgrade.
    • DarrenM's avatar
      DarrenM
      Sr. NETGEAR Moderator
      Hello BennyTm and Shalverson
      When you upgraded did you uninstall your drivers for the 6200 and reinstall the windows 10 drivers? if not i would suggest removing all the drivers and doing a reinstall of them and when doing this remove the 6200 and wait untill  you have all the drivers installed. Also make sure you have your PC drivers up to date for your usb ports. Hope to hear your feedback
      DarrenM
