searawd
Jan 22, 2016Follower
A6210 Adapter Disconnect Issues Windows 10
For the past few months I've been using the Netgear A6210 adapter and have had the ongoing problem of it disconnecting from devices. I first purchased the adapter back in September for my laptop (ru...
JamesGL
Jan 31, 2016NETGEAR Employee Retired
Hi searward,
Have you tried connecting it to the laptop again and check if the same problem happens?
When installing in your PC, disable antivirus and firewall and also use the standalone driver instead of the driver with Genie.
