torrmundi
Sep 30, 2016Follower
A6210 Windows 10 Airplane Mode
Hey, I was using my A6210 with Genie 10.0.0.34 on a Windows 10 PC when the device started disconnecting repeatedly within minutes, then seconds. I uninstalled Genie, got the 10.0.0.35 install...
JamesGL
Oct 13, 2016NETGEAR Employee Retired
Hi torrmundi,
Please post the screenshot of the Airplane mode error and the Genie.
JamesGL
Community Team
- LusthawkApr 03, 2017Aspirant
I'm having this same problem with Windows 10 and the Netgear A6210. I need a workaround or updated drivers asap; very frustrating. There's no error code to post, it's just that Airplane Mode will NOT turn off. If you click it on the taskbar nothing happens, if you go to it and network settings and slide the bar to off it immediately slides back to on. This is extremely frustrating...
So far I've tried updating the drivers, using the original drivers, running with Genie installed and uninstalled. I've tried multiple configuration combinations for the device settings (disabling the option to allow the computer to turn off the adapter, etc). Please help...
