acela13
Aug 19, 2018Aspirant
a6c100 HIGH RTT LAG/packet loss!
Hi. Explain why the whole point of this card is moot after some sort of weird software glitch? It did work just fine, then earlier this month, for whatever reason after an update? High RTT LAG with A...
michaelkenward
Aug 20, 2018Guru - Experienced User
If I can unravel that, you have an A6100 and it has stopped working after some sort up update?
Update to what?
I have just run an update for the Netrgear software on my A6100, it is running just fine after the update. (Thanks for alerting me to this update.)
My Windows 10 64-bit is also up to date.
acela13 wrote:
To make matters worse, my onboard wifi adapter gets shut off by Windows randomly and refuses to work again until a reboot.
Maybe there is a problem with the wifi source? What is that? A router of some sort?
Blanca_O
Sep 02, 2018NETGEAR Employee Retired
Hi acela13,
We’d greatly appreciate hearing your feedback letting us know if the information michaelkenward provided has helped resolve your issue or if you need further assistance.
Blanca
Community Team
