shadowfax20
Jun 16, 2021Aspirant
A7000 Genie application does not start in WIN10
everything works fine except for this application; it does not start
Thanks to Google, I just found this:
genie | Product | Support | NETGEAR
It works. But grab it while you can.
I have no idea what you mean by "change of MgH".
You refer to the "genie application". This could be one of several things, the browser interface, a Windows or Mac program for a PC, or a mobile Android/iThing app. Netgear labels them all as genies. Which are you using?
- shadowfax20Aspirant
I am using it for WIN10. It worked. I can connect, but I do not have access to the software of the WIFI adapter. I am clicking the icon and nothing. I also reinstall the software.
shadowfax20 wrote:
....I do not have access to the software of the WIFI adapter.
What software is that? What do you want to do with it?
