TurboVin
Apr 04, 2026Aspirant
A7500 recurring BSOD when used as Hyper-V virtual switch — WinDbg points to mtkwl6eux.sys
Experiencing recurring BSODs with my A7500 when configured as a Hyper-V external virtual switch on Windows 11 24H2. 4 crashes in 6 days. The adapter works fine in normal (non-Hyper-V)
usage.
Reproduction (on my system):
1. Enable Hyper-V on Windows 11 24H2
2. Create an external virtual switch bound to the A7500 shared with mgmt OS
3. Connect to a WiFi network
4. System BSODs within hours to days
WinDbg analysis of the full kernel memory dump points to mtkwl6eux.sys (though I'm not a kernel debugging expert, so corrections welcome):
- Bugcheck 0x139 (KERNEL_SECURITY_CHECK_FAILURE), param 0x3 — LIST_ENTRY corruption
- A system thread created by mtkwl6eux.sys waits on an I/O buffer (pool tag IoSB) in nonpaged pool
- The wait block for this thread is corrupted — both list pointers zeroed, Thread field NULL — consistent with a double-remove or use-after-free
- Thread stack: mtkwl6eux → ndis!NdisWaitEvent → nt!KeWaitForSingleObject
- The crash occurs when Windows' ETW subsystem enumerates threads and walks the corrupted wait list
- All dumps have identical stacks. Failure bucket: 0x139_3_CORRUPT_LIST_ENTRY_nt!KiFastFailDispatch
- Driver's internal PDB references MediaTek MT7921AU — may affect other adapters using the same chipset
Ruled out: RAM (memory diagnostic passed), other drivers (corrupted memory and thread both trace to mtkwl6eux.sys), hardware (adapter works fine without vSwitch).
Workaround: Move the Hyper-V virtual switch to a different adapter. Crashes stop.
Environment: Windows 11 Pro 24H2 Build 26100.8037 | mtkwl6eux.sys v1.0.0.125 (latest) | USB 3.0 | Hyper-V + HVCI enabled
Anyone else seen this? I've also opened a support case. Happy to share more dump details.
Doing a search online with mtkwl6eux.sys seems to turn up alot of results of others seeing this issue for that file.
Might have a look as see if anyone has resolved this if the V Switch is enabled. If not you may need to not use it with this particular adapter.
