cyndane
Jul 28, 2016Aspirant
AC1200 USB WiFi Adapter - Intel/AMD
Simple question:
I was looking at the specs on this USB adapter and it stated it is for a "Pentium Class PC". Am I right (or wrong) to assume that this will not work on a PC that uses an AMD processor? Any help would be great. Thanks in advance.
Edit: This is for a Win8.1 64bit system
Hi Cyndane,
"Pentium Class PC" is a chip classification that was produce 1995 onwards and AMD is part of it. So the answer to your question is it should work with the AMD processor.
JamesGL
Community Team
- JamesGLNETGEAR Employee Retired
Hi Cyndane,
JamesGL
Community Team
- cyndaneAspirant
Thank you so much. :)
- VE6CGXMaster
I think you misread it. It is minimum requirement to use that adapter. If AMD cpu/APU has same level of performance level wny not? Also there is minimum amount of memory requirement in addtion.
