TheMustangGT
Jun 19, 2016Aspirant
Adapter turns off and i loose connection (Windows 10)
So i have this Wifi USB adapter now since November 2015. My concern is, when i play games which need internet to play, then my Wifi stick Turns off and i loose connection. Soon after that it connects...
JamesGL
Jun 22, 2016NETGEAR Employee Retired
Hi TheMustangGT,
1. When you say it turns off did you mean the adapter is no longer detected or the wireless connection is disconnected?
2. Do you have other wireless devices that works fine or have stable connection from your router?
TheMustangGT
Jun 24, 2016Aspirant
1. I mean that the whole wifi stick turns off and i only see a red cross where the wifi symbole should be. Then it takes up to 10 seconds till it restarts. 2. Yes i have 2 Phones, 2 TV's, and 4 other computers at different times connected to the wifi without any problems. So im a hundred % shure that it is the wifi stick since i have build in wifi with my Motherboard and it worked but i lost my Wifi antennas.
