TheMustangGT
Jun 19, 2016Aspirant
Adapter turns off and i loose connection (Windows 10)
So i have this Wifi USB adapter now since November 2015. My concern is, when i play games which need internet to play, then my Wifi stick Turns off and i loose connection. Soon after that it connects...
TheMustangGT
Jul 02, 2016Aspirant
Today it happened again and i klicked on troubleshoot problems and i got one problem that got fixed. The problem was called: The default getaway is not available. and then it says Fixed and the wifi works again.
JamesGL
Jul 12, 2016NETGEAR Employee Retired
Hi TheMustangGT,
Do you have other Windows 10 computer? if yes, try to install it on a different Windows 10 computer and check if the same issue.
